How to write service for assign status for program??
  • October 1, 2020
  • 2 replies
  • 1757 views
            I want to show status of  program starting before 2 hrs and  15 min before if program is start then I want to show status is ON  and after finish program it show me Your program  is expired
I have two use case for assign status for program as below
1) I want to assign program/Batches  for every day
2) Assign program weekly once or twice programs
 please refer below attachment for better understand and suggest how to write service for assign status for program??
Thanks in advance
Best answer by PaiChung
The simple answer is you probably want to use Schedulers/Timers to create events at certain times or at certain intervals to evaluate what time is it currently vs. what your program is scheduled for. Also if a program actually starts, you can toggle a property to track that it is running/off
PaiChung22-Sapphire IAnswer
22-Sapphire I
October 1, 2020
RM1214-AlexandriteAuthor
Thanks for your reply, Can you please suggest in detail How do I used scheduler/timer for calculating status and how to bind ? or Is their possible through service if it Yes then how to write service for assign status for program??
Hello @RM12
Please refer following article for your reference:
https://www.ptc.com/en/support/article/CS328097
https://www.ptc.com/en/support/article/CS243376?&posno=2&q=create%20scheduler%20thingworx&source=search
Hope it will answer your query.
Om Dukiya
Community Manager
October 26, 2020
Hi @RM12.
If one of the previous responses answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
