Y-Axis values over bar
  • September 28, 2020
  • 1810 views
Hi
I have imported CharWidget - v3.0.3 extension from the marketplace, which allows the label chart to view Y-Axis values on the bar using ShowValues option under properties, but I don't see such option listed in the properties section. Is there a way I can achieve the following.
Thanks and Regards
Ketan Agarwal
ketanaga1-VisitorAuthor
Hi
Any update on the following request?
Community Manager
October 6, 2020
Hi @ketanaga.
Which version of the platform are you running?  In the latest version of the Custom Chart widget (which is now available on the support site under the relevant ThingWorx version), the value does display on hover.  Not sure this is what you were looking for.
Perhaps I'm overlooking it, but I was not able to find the property you indicated in the documentation for the version you're running.  You can make a suggestion for this feature on the ThingWorx Ideas page.
--Sharon
Hi
I am currently running TWX 8.5 and imported v-3.03 of the chart widget extension. The requirement here is to have the y-axis value to be displayed on top of each bar rather than hovering over it.
Regards
