how to create service using JavaScript code in particular Thing
  • April 26, 2023
  • 2 replies
  • 1525 views
how to create service using JavaScript code in particular Thing. I created new Thing code using but how to create service using JavaScript code in particular Thing code.
step1:   Thing created using JavaScript code.
var params = {
name:"Scheduler_Dynamic_CRON139ol" /* STRING */,
description: "DEMO Scheduler With CRON dynamically set" /* STRING */,
thingTemplateName:"MyCustomScheduler" /* THINGTEMPLATENAME */,
projectName:"MailserverGoogle" /* PROJECTNAME */,
runAsUser:"Hariharasuthan",
schedule:"0 0/1 * * * ?"
Resources["EntityServices"].CreateThing(params);
step2: below this is service code but how to implement in Thing(step1) using code wise implementation?
Things["Mailserver_google"].SendMessageWithAttachment({
cc: "harisuthanlive@gmail.com" /* STRING */,
path: "52.xlsx" /* STRING */,
bcc: undefined /* STRING */,
subject: "me test Report one mintues " /* STRING */,
fileRepository:"SystemRepository" /* THINGNAME */,
attachmentName:"52.xlsx" /* STRING */,
mimeType:"application/vnd.openxmlformats-officedocument.spreadsheetml.sheet" /* STRING */,
to: "jj@gmail.com" /* STRING */,
body: "Report At"+datetime/* HTML */
Best answer by TravisPickett
@Hariharasuthan
I have never created dynamic services like this nor ever had the need in my years of developing in TWX.  Is there a reason you can't create these services on your custom thing template and use parameters to fill out the appropriate fields?
Travis
Hello @Hariharasuthan,
There are multiple posts on this forum asking this question:
https://community.ptc.com/t5/ThingWorx-Developers/Create-service-programmatically/td-p/518587
https://community.ptc.com/t5/ThingWorx-Developers/Modify-service-code-programmatically/m-p/515218
And also here is a PTC article: https://www.ptc.com/en/support/article/CS372728
My understanding is that it isn't really recommended to do this, even though there are some ways of "kinda" doing it.
Jens
Hi jens
i try inthis code test  but not reflected ,so need simply  way code please share to me
my requirement Is:
particular thing in create new services
 for example
var params = {
name:"Scheduler_Dynamic_CRON139" /* STRING */,
this code was create new thing, but i need to same thing new services how create  ?
@Hariharasuthan
Travis
