link widget transfer parameter to another mashup
CZ_9645217
Dear community,
I now have a requirement to click on a text to jump to another page and pass that text as a parameter to the other page that opens. My current approach is to use a link widget and a button widget to accomplish this, but there are many such requirements on this page, if I use both widgets to accomplish this, it will be very troublesome, is there a better way to achieve this? Thank you!
@CZ_9645217 ,
I would suggest using Session Variables to accomplish this.  You can add variables to the GlobalSessionProperties ThingShape (or create your own ThingShape and add it to the Configuration in the UserManagementSubsystem) and then they will be available under the 'Session' tab in the mashup builder.  You'll have access to those global properties (as well as the change events for them) across all mashups.  Hope that helps.
--Nick
2 REPLIES 2
@CZ_9645217 ,
--Nick
CZ_9645217
(To:nmilleson)
@nmilleson Thank you very much, it helped me, I used buttons and navigation function to achieve the needs
