I want to change the thickness and color of the bars in the bar chart widget in the vuforia studio. I can't find a way to do this.
The only options that I found are this:
Chart.defaults.global.legend.position="bottom";
Chart.defaults.global.legend.labels.fontColor="#912f46";
Chart.defaults.global.defaultFontColor="#00acc8";
Chart.defaults.global.defaultFontSize=20;
Chart.defaults.global.title.display=true;
http://support.ptc.com/help/vuforia/studio/en/index.html#page/Studio_Help_Center/WidgetBarChart.html
Can I change any other options inside of the bar chart and how?
Hi @KlemenM ,
I think this widget is based on Chart.js so possibly you can check this link
https://www.chartjs.org/docs/latest/charts/bar.html
so example when check the first setting in http://support.ptc.com/help/vuforia/studio/en/index.html#page/Studio_Help_Center/WidgetBarChart.html
e.g.
we can then look on
https://www.chartjs.org/docs/latest/configuration/legend.html
and
https://www.chartjs.org/docs/latest/configuration/legend.html#position
and for the line properties you can check https://www.chartjs.org/docs/latest/configuration/elements.html#line-configuration
Hi @RolandRaytchev,
I tried a couple of cases but no luck. For example:
Chart.defaults.elements.bar.borderWidth=2;
