Combining Data out of GetPropertyValue
Good morning everybody.
am using IOT Data within my experince. To do so I use Thingworx & get the data via the Get property value service within Vuforia.
I now want to make a picture visible when two properties have a specific value.
Property 1: Additional Sensor -> its a string which is sent. -> "Endposition Reached"
Property2: Status of Gripper arm -> again a string -> "Active"
When the Properties have the above mentioned value I want to make a picture visible.
Does someone have a hint for me how to do it best? Is it within bindings with filter or is it in the java script of the project?
Thank you!
Martin
