Hello!
As the title says, I have a few experiences running 100% OK. What I need to do is copy them to make modifications. I tried doing it by hand, but when I try to open one in Studio, the software just hangs at the "Initializing Project..." screen and it never moves forward. Does anyone know what I am missing? Surely, an admin should be able to get a copy of an experience, correct?
Hi @HectorAtLmco ,
how did you try to copy the Vuforia Studio Project to the local machine? I believe you simple try to copy the directory form the Experience Service as project? Or did you try some other methods?
But I believe to copy project directory form the ES folder is the only one available option . We could find the folder as specified in the project section if the configuration json on the ES installation e.g.
"projects": {
"storePath": "D:/Vuforia-Studio-ES/studio-es-store/projects",
"staticOps": {
"maxAge": "1 second"
So when we check the experience servrer folder it seem not to be the same - compared to the i project folder in the Studio local installation - sample project:
So if you do not use External data - I think the best option will be to create a new project and to replace the files /data form the mentioned folders
View.js and View.json e.g. Home.js and Home.json and all resources but also app.css file for the styles
If you have a Thingworx data then you need also Data.json, metadata.json and Device.json here in the example form the folder
Local
\Projects\TWXRepositoryModelWidgetTest\src\shared\components
ES Server
D:\Vuforia-Studio-ES\studio-es-store\projects\twxrepositorymodelwidgettest\app\shared\components
Possibly this is not the only opton available -and somebody could share it but , I used this workaround sometimes and it was working for me.
What version are you using?
Hello. Sorry for the delay. We have 9.2.x across the ES Server, ThingWorx and the Clients.
Hi @HectorAtLmco ,
"projects": {
"staticOps": {
Local
ES Server
