I have a list of checkbox. When I insert the checkbox using grid layout, it cannot be scroll down when i preview it. the total checkbox that i need to display is 17. but it only display 11 checkboxes on screen.
How to solve this problem?
Hello MiKha,
Grid Layout Widget doesn't have scrollbar behavior.
The solution migth to be to use a Panel Widget.
http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FWidgetPanel.html%23
So, in a such case try to insert Panel Widget in the cell of the Grid Layout Widget where are located Checkbox Widgets.
Move under Panel Widget, all of these Checkbox.
I have tried this solution but no scrollbars have been displayed even if default CSS stylesheet should display them!
It is a point to investigate deeper.
I think about a standard HMTL/CSS error.
Maybe the scrollbars are hidden by outside area.
Best regards,
Samuel
Hello MiKha,
Best regards,
Samuel
Hi @sdidier, thank you for your explanation.
I've tried to use the panel widget, but there's no scrollbars as you've mentioned.
So, as for another alternative, if I have 16 checkboxes, and I want to put only 8 checkboxes in the first grid layout, and after user checked the 8th checkbox, the first grid layout will be hidden, then the second grid layout containing another 8 checkboxes displayed in the same position with first grid layout .
Is it possible to do that? If yes,what is the steps that I need to do?
Thank you in advance.
I've found the solution for the alternative. Thank you so much for your help @sdidier
