How to bring notes written in creo illustrate while creating sequence in vuforia studio by Javascript.I have written saftey precautions in notes while creating steps in sequence. I want to display it in Vuforia studio while running sequence in View app. How to do it with Javascipt?
Can please anyone suggest the code for this?
Hi @InfinityX
So far I know , in generally 2d annotaitons are not available/ in Studio newStep event .
But for the step started and stepfinished events- I think there are some parameters which we can use / and the note form Creo /In UI in the parameter tab is also comming
You can test with some code like this:
var _stepDescription; // private member
Object.defineProperty($scope,"stepDescription",{
get: function() { return _stepDescription; },
set: function(value) { _stepDescription = value;
if(_stepDescription) $scope.setWidgetProp("3DLabel-1", "text", _stepDescription); }
$scope.$on('stepstarted', function(evt, arg1, arg2, arg3) {
var parsedArg3 = JSON.parse(arg3);
console.warn(evt);
console.warn(arg1);
console.warn(arg2);
console.warn(arg3);
console.log("stepName="+parsedArg3.stepName);
console.log("stepDescription="+parsedArg3.stepDescription);
console.log("nextStep="+parsedArg3.nextStep);
$scope.stepDescription=parsedArg3.stepDescription;
//$scope.view.wdg['label-1']['text'] = "Event: " + evt.name + " arg3 fields, name: " + parsedArg3.stepName + " duration(ms): " + parsedArg3.duration + " total steps: " + parsedArg3.totalSteps + " step desc: " + parsedArg3.stepDescription ;
The arg3 contains the more relevant information - here e.g. :
{"stepNumber":2,"stepName":"Step 2",
"stepDescription":"Notiz zu step2",
"duration":6878,
"acknowledge":false,
"acknowledgeMessage":"",
"totalSteps":5,
"nextStep":3}
The example above show the usage /arguments for stepstarted
But it should the same also for stepcompleted - difference is that the one event is stated on step start and the other as the step is completed and also ,may be , there are some parameter in the arg3 different / next step ... etc , not sure/ but you can check it by simple print it to the console with console warn().
Example for stepcompleted:
/////////////////////////////// 'stepcompleted'
$scope.$on('stepcompleted', function(evt, arg1, arg2, arg3) {
console.warn(arg3);
console.log("stepcompleted stepNumber="+parsedArg3.stepNumber);
if(parsedArg3.stepNumber) {
$scope.app.params['my_current_step']=parsedArg3.stepNumber;
my_play_loop(parseInt(parsedArg3.stepNumber),5000);}
