How to delete a view in vufoira studio?
mn1
Hi there,
how can I delte an second view which I created but not use anymore?
Thanks for help!
sdidier
(To:mn1)
Please follow these steps :
  1. In Vuforia Studio, in your Project, in the Project panel (at left), in VIEWS category
  2. Select the View to delete
  3. At right, in the VIEW - DETAILS panel, click the Remove buttonVuforia_View_delete_view.png
  4. In the Delete View dialogbox, click the Delete button to confirm deletion of this View
Best regards,
Sam
5 REPLIES 5
sdidier
(To:mn1)
Best regards,
Sam
whity
(To:sdidier)
Do you also know how to change the name of a view?
And how to copy a view would be nice 😃
sdidier
(To:whity)
To rename a View, follow the same steps, execpt at the step 3, click the Rename button.
To copy a View, saddly this feature doesn't exist today.
Best regards,
Samuel
Hi @whity ,
I want here only to mention that in the previously releases (over 1 year ago)  did have very bad experience with renaming of views . So I did got some time views where nothing work properly and it was not possible to fix it. Especially when the view has some spaces etc...
Therefore first do a backup / e.g. export of the project.
So here an example ... when you have some things like:
2019-02-07_14-29-40.gifI
This means you have some references which pointed directly to a particular view (here the Home.
But... I did often do the following and for small view was working but...(strongly not supported !
Therefore make a copy of you project for the case that some thing is going wrong. Do no follow the next step before having a backup of the project!)
1.) close the project
2.) go the directory
>your user \Documents\VuforiaStudio\Projects\<ProjectName>\src\phone\components
3.) Copy the both file for the view. Here Home.js and Home.json
4.)open the both new files with a text editor here... Home-Copy.js and Home-Copy.json and replace all "Home" string by "Home-Copy" string
5.) go to  >your user \Documents\VuforiaStudio\Projects\<ProjectName>
and open the appConfig.json adn copy the view json sub object and rename it
6.) open the project
Hier in this case - sample prject was  working fine.
Thanks @RolandRaytchev , that's great!
