Hello, in my current AR project I'm trying to implement in an AR experience made with vuforia studio a mqtt client in order to fetch datas from a mqtt broker. I was wondering if there are mqtt dependencies that are possible to install in the project in order to create a mqtt client and subscribe to a specific topic.
Thanks in advance
Hi @FC_12202090 ,
I believe that should be addressed to the Thingworx developer communty - https://community.ptc.com/t5/ThingWorx-Developers/bd-p/twxdevs
So I believe the workflow should be to use a MQTT extension in Thingworx and then set the value to a property of Thingworx thing and then link that property to Vuforia Studio or use an Thingworx service from Vuforia Studio which involve the extension
Please, see also the posts:
https://community.ptc.com/t5/ThingWorx-Developers/MQTT-Extension/m-p/755557
https://community.ptc.com/t5/ThingWorx-Developers/Where-to-get-MQTT-extension-2-1-2/m-p/887144
https://community.ptc.com/t5/ThingWorx-Developers/Regarding-MQTT-extension/m-p/748417
https://www.ptc.com/en/support/article/CS325300
Hi @FC_12202090 ,
furhter found PTC Technical Support article
How to use the ThingWorx MQTT (Message Queuing Telemetry Transport) Extension in ThingWorx Platform
