Layout Problem in 2d View
SlowJ
Hi Everyone,
I just created a new empty 2d View in Vuforia Studio.
I added a footer with a grid layout inside but the grid layout does not cover the full width. (see Screenshot)
Now I would like the footer to stretch full width with a 3 Column Layout with elements on the left, right and center of screen.
How can I achieve this?
tmccombie
(To:SlowJ)
The grid actually does cover the whole width, it just looks a little wonky in the canvas. If you preview or publish and view on a device, you should see that the items are displayed correctly. I created 3 columns with a button in each and set each columns justification & alignment to 'center'.  I confirmed that it displays correctly on an iPhone and iPad.
You can also manually define your column width within the column properties.
tmccombie
(To:SlowJ)
SlowJ
(To:tmccombie)
Hi tmccombie,
Thank you for the quick response!
You are right it only looks strange in the canvas.
When I start the Preview everything works like expected.
