Model metadata in 2D view
GianVal
Hello, is it possible to use model metadata in a 2D view? I just need to display some information about the model in a separate 2D view of the experience and don't know how to access those data. how to do that?
many thanks
SteveGhee
(To:GianVal)
simple example attached.
i had forgotton to mention that you need to pull the metadata in first, which you do in the 3d view (i had something else doing that, forgot it was there. sorry about that)
so, in the 3d view, you'll see a simple 'loaded'()' function which pulls in the metadata by doing a dummy call to the API.  it doesnt actually need to do anything with the data, although you pbviously could use this in the 3d view if you needed to.
once in memory, you can switch to the "details" view, which you can then see is doing a specific query. The results are displayed in a label.
hope this example clears things up.
7 REPLIES 7
Hi @GianVal ,
I think the meta data API as documented in the Help http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2Fcad_metadata_api.html
could not be used in 2D view. But you can download the JSON file correspoinding to the PVZ to the Upload  project folder or to a string variable via TWX LoadJSON service . In this case you can  use some old techniques as described in first section  of the tech tip https://community.ptc.com/t5/Vuforia-Studio-and-Chalk-Tech/Incorporate-CAD-Metadata-Into-an-Experience-version-8-5-13-and/ta-p/693341
Further when I tes some code like this:
$rootScope.$on('modelLoaded', function() {
  PTC.Metadata.fromId('model-1').then ((metadata) => { console.warn(metadata); console.log(JSON.stringify(metadata)) })
this will print in the console
so seems that this object of the meta data with api methods is not so easy to be importetd as json to the project. (my opinon after first look) otherwise each javascript structure could be imported as text and then converted with eval function- when we know the exact code 😊
The metadata will persist across views, so if you load a model in a 3d view, keep a record of the element name (e.g. "model-1") and then you call the metadata API within another view e/g/ a 2D view, you can make all the metadata calls.
let me know if you need an example.
GianVal
(To:SteveGhee)
I tried with this call in the source code of the 2D view
$scope.visualizzameta = function() {
    PTC.Metadata.fromId('model-1').then((metadata) => {
        var pathId = '/'
        var part_name = metadata.get(pathId, 'epmdoc_CODICE_FORN')
        console.log("part name", part_name);
        $scope.setWidgetProp('label-1', "text", part_name)
it returns undefined.
Please can you provide me an example? Many thanks
SteveGhee
(To:GianVal)
@SteveGhee ,  yes agree - I did not consider the option to create first 3D view  with modelwidget to dispaly the model and add the json data. Thanks
Tes, the key is that you must first load the model to get its metadata!  hence load (and fake metadata call to force load) and then the data will be present.
There are other ways you could bring the data in - there is Metadata.fromData(name,data) entry point that will bind in-memory data that may have come from elsewhere.   I can leave you folks to experiment 🙂
