cannot publish from Vuforia studio
rsingaram
Hi
Can someone help me on this to be working in my laptop. Two months back,  I managed this issue by accessing from a new workstation. Right now customer has purchased license and so I need to make it work on my laptop,
When I click the "Publish" from Vuforia Studio, it pops out error window as "Local host:3000 says, Uh-Oh ! Publish failed.Check for log errors. Internal Serrver error"
I have attached screen shot and log files herewith.
- Ravi
dupatel
(To:rsingaram)
@rsingaram You can create other user in ThingWorx instance associated with your Studio using the provided Administrator account. Then will have to grant correct permission to get access to Experiences.
Refer to grant user permission help center page. Note, this is for public access however similarly access could be restricted based on requirement.
-Durgesh
7 REPLIES 7
rsingaram
(To:rsingaram)
adding the error on experience server...
dupatel
(To:rsingaram)
@rsingaram Could you please confirm if you are able to validate the Experience Service from project configuration->Info tab.
Also, could you please confirm if you are able to see your Trial service is active by login into https://studio.vuforia.com/login/
If possible attach the snapshot post login to above URL.
Durgesh
rsingaram
(To:dupatel)
Studio is able to publish in another fresh computer using my login.
So I cleaned up registry entries and local files related to Studio.
Now I can publish - Resolved..
- Ravi
dupatel
(To:rsingaram)
@rsingaram Ok Ravi, good to know and I believe you are all set now.
-Durgesh
rsingaram
(To:dupatel)
Hi Thanks
I had posted another question that is very very urgent.
PTC has issued a commercial experience url & thingworx url and mentioned.
How do I configure many users of the company to publish to this server? How
to authenticate each to do so?
There is a user name” Administrator” for the above url with some password.
thanks
dupatel
(To:rsingaram)
-Durgesh
dupatel
(To:dupatel)
@rsingaram If above responses has answered your question, then please mark as Accepted Solution, for the benefit of others who may have the same question.
-Durgesh
