Cleanup of workspace cache folder
Devidas
when I remove objects from workspace, does it automatically remove the files from my hard drive cache folder (.wf)?
Gagan
(To:Devidas)
Hello Davidas
When you remove objects from the work-space ,only the link will removed from the work space and not the meta data
These files are stored in the cache folder location ,usually it will be in C:\Users\*username*\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf\Creo 2.0\Parametric\.cache2008\.cache2008\*server name*
Note: *username* and *server name* is variable depending on your system
in side the server name folder oyu will find two types of files ie .lid and .sid , .lid files represent new or modified files in your local cache that have not been uploaded to the server. and  “sid” files in the local cache represent files that have already been uploaded to the server, (it is usually unnecessary to attempt recovery of these files)
You can delete the cache in 2 methods
1.By deletion the files in the folder (*server name*)
    I don't recommend this , because it it delete all the files from all your work space
2. from Creo 2 Go to File>manage-session>Server management>click on cache tools
          Select the work space that you want to clear and clink on OK (Refer the attached screenshot)
Important Note:make sure there are no locally modified files are new files in the work space , because you may loose the data.
@Eric Metzger
I guess if accumulated cache size is very huge ,say around 18-20 GB , they may face slowness issue in the work space .what is your opinion on this ?
@devias Pawar
Even i am into the admin side , I agree eric's point , if you are looking for delete the .wf files , can we know what is the reason ?
Best Regards
5 REPLIES 5
TomU
(To:Devidas)
It depends.  If you have workspace frames enabled, then the file won't actually be removed from disk until it is no longer being referenced by an existing frame (event).
emetzger
3-Newcomer
(To:Devidas)
No, objects will not always be removed from the cache folders.
But as an Admin, I would ask why you are even looking within the cache folders.
Even as an Admin, I rarely browse cache folders. I delete and rebuild them more than I look within!
Gagan
(To:Devidas)
Hello Davidas
@Eric Metzger
@devias Pawar
Best Regards
emetzger
3-Newcomer
(To:Gagan)
When cache sizes show an excess like 18-20gb, I would first clear the cache from within Creo. If the cache size is hardly reduced, and I have performance issues I feel are cache related, I would rebuild the cache folders (delete and allow them to rebuild). I've done this many times with very good success. PTC even has a timeframe for doing this as a routine.
The critical thing when you delete cache folders and rebuild them cleanly (already noted, but I will note it again!) is to make certain all new and modified objects are checked in, or at least backed up somewhere so you can import the data later.
Devidas
(To:Devidas)
Thanks to all for sharing your views.
Normally I prefer to rebuild the cache folder but not so often. As some users have new objects or concept design which are not uploaded to the pdmlink system.
