Has anyone found a good way to find accidental revisions in Windchill or revisions that never made it back to a released state? It happens somewhat frequently that some objects accidentally get revised by someone and they didn't even know they did it. Or maybe a change was in progress and then the change was abandoned and the CAD was left. I've tried using advanced searches for this but I can't get the search to work - see screenshot below. Or is there a SQL query that would do the trick?
Omg happens all the time here. Hope you find a solution for both of us
You could use Query Builder to make a query for this.
Your main object would be the CAD Document type (or whatever it is you want to search for)
There's a constraint you can add to get latest iterations.
To get latest revisions, you have to add a constraint that uses a Sub-Select. This should be helpful for that: https://www.ptc.com/en/support/article?n=CS1171&language=en&posno=1&q=query%20latest&source=search
From there, you would add your additional constraints to exclude revisions = 1 and so on
@joe_morton The report manager does not work the same way starting in 11.0. The QML file in that article won't even import. I have been trying to figure out how to get it working in 11 but I have had no luck so far.
If you are referring to the QML in CS1171, it loaded into my 11.0 system.
There is a difference between import and upload. These picks should work for QML files.
Site > Utilities > Report Manager > Upload Report Template from QML
Yep. You are correct. Didn't even think about that. It did upload to my system. Thank you.
Here's a good video about the updated Query Builder in Windchill 11.0 - https://community.ptc.com/t5/FlexPLM-Tips/PTC-Query-Builder-for-FlexPLM/m-p/440464
Haven't figured how to build the query yet.
I opened a case with PTC and it looks like this problem has been reported before. CS58285 and CS157314 look like their directly related to why the Advanced Search query isn't working. There's a popular Windchill Idea to fix this: Enable Windchill search to support ‘pure’ latest iteration search when additional criteria is applied. The idea was first reported in 2012 and acknowledged in 2018. Let's hope for a fix soon - keep voting for it! Here's a related article in the Windchill Help Documentation - Non-Latest Iterations Using Multiple Criteria.
"Let's hope for a fix soon"
In two months from now it's been 8 years since that idea was posted. I guess they have to do their due diligence. 😏
I created a Product Idea for people to vote on - https://community.ptc.com/t5/Windchill-Ideas/Find-Accidental-or-Stagnant-Revisions-in-Windchill/idi-p/634178#M10926
Here is an SQL query to find orphan revisions.
SELECT --DISTINCT TOP(60)
ISNULL(lib.namecontainerInfo,'') + ISNULL(prod.namecontainerInfo,'') AS [Context],
edm.CADName AS [CAD Name],
FORMAT(ed.modifyStampA2, 'MM/dd/yyyy') AS [Date],
ed.statestate AS [State],
ed.versionIdA2versionInfo AS [Revision],
ed.iterationIdA2iterationInfo AS [Iteration],
wt.fullName AS [Username]
FROM EPMDocumentMaster AS [edm]
JOIN EPMDocument AS ed
ON edm.idA2A2 = ed.idA3masterReference
AND ed.branchIditerationInfo =
SELECT max(branchIditerationInfo)
FROM EPMDocument
WHERE idA3masterReference = edm.idA2A2
AND edm.idA2A2 = ed.idA3masterReference
AND latestiterationInfo = 1
AND statecheckoutInfo = 'c/i'
-- Get the name of the user who created this version
JOIN WTUser AS wt
ON wt.idA2A2 = ed.idA3B2iterationInfo
-- See if this drawing is in a Library
LEFT JOIN WTLibrary AS [lib]
ON ed.idA3containerReference = lib.idA2A2
-- See if this drawing is in a Product
LEFT JOIN PDMLinkProduct AS [prod]
ON ed.idA3containerReference = prod.idA2A2
WHERE
ed.latestiterationInfo = 1
AND ed.statestate = 'INWORK'
AND ed.versionIdA2versionInfo <> '-'
AND ed.iterationIdA2iterationInfo = '0'
--AND edm.CADName = 'My CAD File'
--AND prod.namecontainerInfo = 'My Product'
--AND lib.namecontainerInfo = 'My Library'
--AND wt.fullName = 'Doe, John'
--ORDER BY edm.CADName
ORDER BY Date
Sample output:
