Hey guys, I'm on Creo Parametric 6.0 and I'm would like to know where can I disable the perpendicularity when I place bubbles in drawings. As you can see below, there is the perpendicularity symbol showing up which makes the placement harder.
Thanks in advance.
It was specifically updated in Creo 4 M130 (released May 4th, 2020).
Since I don't have any specific documentation on this change, I can only guess, but I would say any Creo 6 release after that date likely also has the same update. Those Creo 6 build codes would be 6.0.5.1 and 6.0.6.0 (both released after May 4th, 2020) You can check your installation under File - Help - About Creo Parametric.
Dates are based off of the product calendar https://support.ptc.com/cs/release_calendar/index.html
Check out the solution to this Creo Idea
Option to disable/turn off annotation leader snapping constraints
Hi, it seems like this solution is not in Creo Parametric 6.0.
Is Creo Parametric 4.0 more updated than 6.0 ?
As @StephenW mentioned in the referenced Idea, Creo 4 in an enterprise release and receives support updates longer than 5 or 6. Creo 6 may have never received this update. Are you using the latest release of Creo 6 - 6.0.6.0?
You could also try holding Shift while moving bubbles.
I'm on Creo 6.0.1.0, that explains why I can't see it.
Thx.
