Setting appearances with VB API
cstarnes
Does anyone have an example of how to set assembly or component appearances (preferably by name), using the VB API?
mvitárius
(To:cstarnes)
Maybe the workaround could be that you set the material of the part by vbapi, but for assembly, I don't think it is possible.
That's what I'm doing currently, but it's not reliable. The parts don't always regenerate if the PTC_MATERIAL_NAME parameter is changed.
