@justhumm wrote:
This is sort of a follow-up question to this thread where I was recreating the calculations of the ptc sample:
You may consider closing the threads you opened if you decide to open a new thread for follow ups.
I guess the question in the first link you mention may be considered answered.
I also don't feel that your new question is a follow up as it has nothing to do with the problems you experienced in the other threads.
Your new problem occurs because you used a range in your program. In programs you have to use for-loops instead!
