Best answer by Werner_E
Looks like homework, doesn't it?
Where are your attempts in MC15?
What have you already tried?
BTW, the condition f(x)>= sine is somewhat strange.
First task should be to make a plot (either by hand or via Mathcad) which shows that you are just looking for the minimum of the part of the curve plotted thick red. Fortunately this minimum (green dot) can be found easily using the zero of the first derivative ...
The name "arctg" is quite outdated and should no longer be used according to the current standard (ISO 80000-2)
In Mathcad this function is called "atan".
Werner_E25-Diamond IAnswer
6-Contributor
May 22, 2024
And how do you find the solution of it?
6-Contributor
May 23, 2024
Is it right? I'm sorry if everything is a mess here.
Community Moderator
May 16, 2024
Hello @TT_11056782
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
