Best answer by Werner_E
Looks like homework, doesn't it?
Where are your attempts in MC15?
What have you already tried?
BTW, the condition f(x)>= sine is somewhat strange.
First task should be to make a plot (either by hand or via Mathcad) which shows that you are just looking for the minimum of the part of the curve plotted thick red. Fortunately this minimum (green dot) can be found easily using the zero of the first derivative ...
The name "arctg" is quite outdated and should no longer be used according to the current standard (ISO 80000-2)
In Mathcad this function is called "atan".
Werner_E25-Diamond IAnswer
6-Contributor
May 22, 2024
And how do you find the solution of it?
@TT_11056782 wrote:
I mean the whole question since it's subjected to this
I already edited my answer above.
After making the plot and seeing that this constrained is fulfilled anyway by the minimum we get when we set the first derivative to zero, its not further considered.
To be on the safe side you can, after finding the x.min value, make a check to see if this constrained is fulfilled.
Community Moderator
May 16, 2024
Hello @TT_11056782
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
