Simplify program using for loop
CarlosRomero
Hi Guys,
Can anybody to simplify this program?
I must run for “k” and “i” twenty times the block.
CarlosRomero
LucMeekes
(To:CarlosRomero)
Hi Carlos,
should be as simple as embedding the two for loops in yet another for loop.
See if this is what you need.
7 REPLIES 7
LucMeekes
(To:CarlosRomero)
Hi Carlos,
You should attach your Prime worksheet, not just a picture.
And state which version of Prime you are using.
CarlosRomero
(To:LucMeekes)
Hello Luc.
See attached files.
CarlosRomero
LucMeekes
(To:CarlosRomero)
Hi Carlos,
CarlosRomero
(To:LucMeekes)
Luc, the program does not return results.
See the attached image.
Luc had disabled autocalculation in his sheet.
So either turn it on again or Press F9 to force (a single) re-calculation of the sheet.
CarlosRomero
(To:Werner_E)
Thanks Luc and Werner.
It's OK.
CarlosRomero
