Simplify program using for loop
  • February 7, 2024
  • 3666 views
Hi Guys,
Can anybody to simplify this program?
I must run for “k” and “i” twenty times the block.
CarlosRomero
Best answer by LucMeekes
Hi Carlos,
should be as simple as embedding the two for loops in yet another for loop.
See if this is what you need.
Hi Carlos,
You should attach your Prime worksheet, not just a picture.
And state which version of Prime you are using.
Thanks Luc and Werner.
It's OK.
CarlosRomero
