ENGAGE - KUDO, REPLY, or SOLVE!
Below are the top engaging PTC Community threads for June! See if your community username made this list! Or, read more about a topic that interests you!
Two older Creo posts received top views last month!
1. Creo: This post by @ptc-1647943 regarding How to show or draw center mark
received top views last month! Thank you @SkyKing @troesch @DavidButz @ptc-759514 @vcpu14 @ptc-5114571 @BrandonCroft @ptc-4877655 @JWayman @sdensberger @TomD.inPDX @Dale_Rosema for contributing to this thread!
https://community.ptc.com/t5/3D-Part-Assembly-Design/how-to-show-or-draw-center-mark/m-p/116910
2. Creo: The Centre of Gravity (CG) for parts, assemblies and drawings to be shown as icon? started by @Bhoopathy received top views last month! Thank you @pimm @KenFarley @BrianTaylor @Shahbazk61 @ghkhkjhkjh @rrich-2 @AntonioVieira @Roy_Crerar for contributing to the thread!
3. ThingWorx: @nahuel received an Accepted Solution for his post Anomaly Detection Server Sizing
https://community.ptc.com/t5/ThingWorx-Developers/Anomaly-Detection-Server-Sizing/m-p/734369
4. ThingWorx: @Raja_Redeem inquired if Google Single sign-on can be implemented with ThingWorx application as SSO?
5. ThingWorx: @cbaurand asked about Mqtt extension “System” user
https://community.ptc.com/t5/ThingWorx-Developers/Mqtt-extension-quot-System-quot-user/m-p/732417
6. ThingWorx: @vcavic started a post Add some Attributes in Part List
https://community.ptc.com/t5/Thingworx-Navigate/Add-some-Attributes-in-Part-List/m-p/733439
7. ThingWorx: @AP_9587236 asked about the textbox widget…But why the default values of infotable not passing to the Textbox widget.??
https://community.ptc.com/t5/ThingWorx-Developers/textbox-widget/m-p/735528
8. Vuforia Studio: @Qwtll received an Accepted Solution for his post regarding 3D Panel distance (currently too far)
https://community.ptc.com/t5/Vuforia-Studio/3D-Panel-distance-currently-too-far/m-p/733071
9. Vuforia Studio: @Qwtll started another great post about How to reset whole experience while in AR World
10. Vuforia Studio: @pjahn asked about Vuforia Experience Service on Linux-Best practive to run it as a daemon
11. Windchill: @ScottMorris received an Accepted Solution from @Ajit_Kulkarni for the inquiry about
WVS CAD Worker Optimization and Memory Management Thank you @rhart and @BjoernRueegg for participating in the thread!
12. Windchill: @gmydoor-2 received an Accepted Solution from @d_graham for his question regarding the code to republish failed jobs. Thank you, @BenLoosli and @BjoernRueegg for contributing to the thread!
https://community.ptc.com/t5/Windchill/code-to-republish-failed-jobs/m-p/734179#M64183
13. Windchill: @khimani_mohiki posted about WVS AfterLoader deleting secondary content with helpful responses from @MikeLockwood and @d_graham
https://community.ptc.com/t5/Windchill/WVS-AfterLoader-deleting-secondary-content/m-p/731932
14. Windchill: @Ajit_Kulkarni provided an Accepted Solution to post by @KevinBradberry Modification Uploaded (blue plus sign)-how to clear it
15. Arbortext: In June, @rl bumped up a thread Using HTTPS/SSL to connect to Arbortext Publishing Engine by @Tusken_Raider
16. Arbortext: @EL_9959997 received some help from @GarethOakes related to Error “All subprocesses are currently busy”
https://community.ptc.com/t5/Arbortext/Error-All-subprocesses-are-currently-busy-quot/m-p/732782
17. Windchill SSE: @EP_9964574 revitalized the GIT Integration usage and overview
conversation started by @ASailer Thank you, @bson21 @Ted_Lin @sdas-4
18. Windchill SSE: @Chittaranjan_11 asked about How to compute the count of Requirements having no Assigned User Set in a RQ Doc?
19. Mathcad: @Cornel got some help from @LucMeekes on Bod Plot: Mathcad 15 vs Mathcad 11
https://community.ptc.com/t5/PTC-Mathcad/Bode-Plot-Mathcad-15-vs-Mathcad-11/m-p/734615
20. Mathcad: @SA_9950729 received an Accepted Solution from @ttokoro for the topic Combo-box alternative methods of utilization
Thank you @Fred_Kohlhepp and @LucMeekes for also participating in the conversation!
