October Noteworthy Community Posts
Jaime_Lee
Community Manager
ENGAGE= KUDO, REPLY, or SOLVE!
Below are the top engaging PTC Community threads for September! See if your community username made this list! Or, read more about a topic that interests you!
October = month of Creo Community Throwback Threads!
An anomaly...two of our most viewed posts in October did not have any replies but STILL made it as "Most Noteworthy" with top views!!
1.  Creo:  The  Placement Disappeared topic was started by  @trohwedder   in 2015 discussed …”Creo 3.0 on Windows 10…”, This older lively conversation between  MartinHanak, StephenWilliams Mahesh_Sharma  can assist other community members with similar issues!
 https://community.ptc.com/t5/Part-Modeling/Placement-disapperaed/m-p/288455
2. Creo:  @ptc-5103358 started the 2013 topic PTC Quality Agent ...” when I try to run CREO Parametrics always says that I have to register the quality agent.”
 Great contributions by TomDinPDX, VladimirN, MartinHanak  @AdamHaas   @ptc-6859503   TomU
https://community.ptc.com/t5/Creo-Modeling-Questions/PTC-Quality-Agent/m-p/137060
 Another throwback thread!
3.  Creo:   @DS_8977438 revitalized the Home licenses topic started by  @Gucio  in 2017 .  Great contributions by @Dale_Rosema   TomU, @KenFarley , @StephenW  MartinHanak,  @ptc-5472289 , @kk87 @kk87 , @BernardWielfaer , @LukaszMazur
https://community.ptc.com/t5/System-Administration/home-use-licenses/m-p/385645
Most noteworthy view AND Engagement  Creo thread for October
4.  Creo:  @davehaigh  began the comprehensive topic Switching from Stroked Fonts to True Type Fonts - Drawings & Models - Observations & Questions. Great collaboration with @Chris3  and  @zmiller  Some of our most engaged members  @BenLoosli , @MartinHanak , @TomU  also provided support!
https://community.ptc.com/t5/System-Administration/Switching-from-Stroked-Fonts-to-True-Type-Fonts-Drawings-amp/m-p/692911
5.  ThingWorx:  Great use of a support article to answer How to handle daylight savings and timezone offset values topic started  by @Willie
https://community.ptc.com/t5/ThingWorx-Developers/How-to-handle-daylight-savings-and-timezone-offset-values/m-p/690929
6.  ThingWorx:   @SrijithKrish received some help from PTC Technical Support and @nmilleson to find “… a way that the 'service invoke complete' trigger can used in a subscription?”
https://community.ptc.com/t5/ThingWorx-Developers/Is-there-a-way-that-the-service-invoke-complete-trigger-can-used/m-p/691021
7.  ThingWorx:  @Saranya_Sstarted “Influx DB - ThingWorx 9.0 “ thread  and received an Accepted Solution!
https://community.ptc.com/t5/ThingWorx-Developers/Influx-DB-ThingWorx-9-0/m-p/691080
8.  ThingWorx:  @iguerra brought to community’s attention the Code inspector warning with “for each” Thank you,  @BennyB for contributing to this thread!
https://community.ptc.com/t5/ThingWorx-Developers/Code-inspector-warning-with-quot-for-each-quot/m-p/690202
 9.  Vuforia:   @TB_9645821 asked a startup Vuforia Studio Trial question and received steps to configure his Vuforia Studio.
https://community.ptc.com/t5/Vuforia-Studio/Vuforia-Studio-Trial/m-p/691012
10.   Vuforia:   @leonardosella asked a great question about CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource and received an Accepted Solution to his query!
https://community.ptc.com/t5/Vuforia-Studio/CORS-policy-No-Access-Control-Allow-Origin-header-is-present-on/m-p/691705
11.  Vuforia:  An accepted solution for the question “Is it possible to pass value from one experience to another” was posted by @Velkumar
https://community.ptc.com/t5/Vuforia-Studio/Is-it-possible-to-pass-value-from-one-experience-to-another/m-p/690999
12.   Vuforia:   @AM_9646193 asked for help with Creo Illustrate invalid Host ID with using Vuforia Studio.
https://community.ptc.com/t5/Vuforia-Studio/Creo-Illustrate-Invalid-Host-ID/m-p/692254
13.   Windchill:  @hshall02 had assistance from @BrianToussaint   @BrianToussaint, and an accepted solution from @ScottMorris on how to Disable delete permission in Classification Administration
https://community.ptc.com/t5/Windchill/Disable-delete-permission-in-Classification-Administration/m-p/691070
14.   Windchill:  @colonso bumped up the 2010 Automatic fill of Line Number in BOMs thread started by  @Alex1988  with an excellent suggested solution from  @d_graham
https://community.ptc.com/t5/Windchill/Automatic-fill-of-Line-Number-in-BOM-s/m-p/630821
15.   Windchill:  @mvaatanen-2 received some insight from @STEVEG , TomU, BenLoosli for his query PSM is going to end of lifecycle with current Architecture  Shout out to@dduncanfor drawing community attention to a helpful knowledge article.
https://community.ptc.com/t5/Windchill/PSM-is-going-to-end-of-lifecycle-with-current-Architecture/m-p/683032
16.   Windchill:  @khimani_mohiki  received an Accepted Solution for How to Prohibit Publishing of CAD Documents based on Name
https://community.ptc.com/t5/Windchill/How-to-prohibit-publishing-of-CAD-documents-based-on-name/m-p/691025
 17.  Arbortext:   @BobSpangenburg  collaborated with GarethOakes to find an answer to “Capacity exceeded: DISPATTR page table entries" error
https://community.ptc.com/t5/Arbortext/quot-Capacity-exceeded-DISPATTR-page-table-entries-quot-error/m-p/692782
18.  Arbortext:  @Ren11234 received help for his Invalid Schema/DTD File from  @GarethOakes
https://community.ptc.com/t5/Arbortext/Invalid-Schema-DTD-File/m-p/691928
19.   Windchill SSE (Integrity):  @EL_9679973 found out how to send a large amount of content to the text field of the document
https://community.ptc.com/t5/Windchill-Systems-Software/Asks-how-to-send-a-large-amount-of-content-to-the-text-field-of/m-p/694482#M7365
20.   Mathcad:  @ValeryOchkov   @Werner_E , @FredKohlhepp @GrumpyOldTom  @MaxNori  @FredKohlhepp participated in What name has this closed curve? which is the Community MGR’s pick for most enjoyable thread of the month to read!
https://community.ptc.com/t5/PTC-Mathcad/What-name-has-this-closed-curve/m-p/694358
2 REPLIES 2
TomU
(To:Jaime_Lee)
Jaime_Lee
Community Manager
(To:TomU)
Thank you! TomU...now updated!
