PTC Community Monthly Stand-Out January 2023
achirila
Emeritus
See the Top Community Engagers and the Top Noteworthy posts for the month of January.
Top January 2023 Community Engagers:
@Werner_E @ttokoro @MartinHanak @HelesicPetr @tbraxton @jensc @TomU @Cornel @Pascal_Brunet @lvl107 @Sathishkumar_C @StephenW @LucMeekes @avillanueva @pausob @VladimirN @BenLoosli @Bernhard @alcubierre @jferguson4 @pshashipreetham @terryhendicott @BTaylor_MEI
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for January 2023!  See if your community username made this list!  Or, read more about a topic that interests you!
1. Creo: NormanParra asked how to drag up the green line at the bottom of an assembly tree or part features. Great contributions by MartinHanak, kdirth and Chris3
https://community.ptc.com/t5/3D-Part-Assembly-Design/Move-quot-Insert-Here-quot-Line/m-p/846794
2. Creo:  JG_10559632 received an accepted solution from kdirth for topic Cosmetic Thread in drawing. Thank you, @StephenW , @tbraxton , and @msmith  for contributing to the conversation!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Cosmetic-Thread-in-drawing/m-p/851178#M127448
3. Creo: Thank you Lars_F for providing an accepted solution for CS_10559331 on this topicCreo 7 3D Cabling Repeat Region and Wire Length
https://community.ptc.com/t5/3D-Part-Assembly-Design/Creo-7-3D-Cabling-Repeat-Region-and-Wire-Length/m-p/851754#M127499
4. Creo: JG_10559632 needed help with UDF Editing and FriedhelmK offered him an accepted solution. Thank you, @tbraxton also for your contribution!
https://community.ptc.com/t5/3D-Part-Assembly-Design/UDF-Editing/m-p/852002#M127580
5. Creo: A question about Tracking down a circular reference was posted by CC_9311904 and an Accepted Solution was provided by Tdaugherty!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Parameters-from-a-txt-file-to-Windchill/m-p/852120#M127533
6. ThingWorx: M4RC gave an Accepted Solution to alcubierre for the topic QueryNamedPropertyHistory does not show anythingThank you, @PaiChung for your input as well!
https://community.ptc.com/t5/ThingWorx-Developers/QueryNamedPropertyHistory-does-not-show-anything/m-p/852273#M60992
7. ThingWorx: The topic timing based on event triggering services, posted by Hariharasuthan received an accepted solution provided by DanZ
https://community.ptc.com/t5/ThingWorx-Developers/timing-based-on-event-triggering-services/m-p/852395#M61002
8. ThingWorx: jensc provided a speedy response and Accepted Solution to the inquiry by Hariharasuthan about Generate file or reports.
 https://community.ptc.com/t5/ThingWorx-Developers/Generate-file-or-reports/m-p/851026#M60914
9. ThingWorx: Mattie555 needed help with Move File From One Repository To Another and Sathishkumar_C provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/Move-File-From-One-Repository-To-Another/m-p/849794#M60847
10. ThingWorx:  AS_1307 posted the topic Issue in creating Thing using RESTAPI and received an Accepted Solution from nmutter. Thank you @DmitryTsarev and @nmilleson for your contribution!
https://community.ptc.com/t5/ThingWorx-Developers/Issue-in-creating-Thing-using-RESTAPI/m-p/848005#M60732
11. Vuforia: Martini3119 shared a post about Creo Illustrate latest supported version. Thank you AmandaZupfer for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Creo-Illustrate-latest-supported-version/m-p/848845#M11462
12. Vuforia: Pawel_D posted a topic about Invoke 3D Audio widget Service "Play". Thanks RolandRaytchev for contributing with the Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Invoke-3D-Audio-widget-Service-quot-Play-quot/m-p/850604#M11479
13. Windchill: tjerome posted the topic Creating a Windchill Dev Environment for Testing and received an Accepted Solution by ML_10533213. Thank you @TomU  and @avillanueva for contributing as well!
https://community.ptc.com/t5/Windchill/Creating-a-Windchill-Dev-Environment-for-Testing/m-p/852569#M70034
14. Windchill: MV_10441462 asked how to create a group and add an existing group as member using the LoadFromFile utility and Pascal_Brunet provided the Accepted Solution.
https://community.ptc.com/t5/Windchill/Create-Groups-and-add-an-existing-group-as-member-using/m-p/852600#M70037
15. Windhill: wharaden1 asked about Vault fill up with an Acccepted Solution by mmeadows-3. Thank you for contributing cstein, Marco_Tosin, BenLoosliavillanueva!
https://community.ptc.com/t5/Windchill/Vault-fill-up/m-p/851929#M69979
16. Windchill: Sha11 asked how to Introduce a new tab in WTDocument Page and HelesicPetr provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/Introduce-a-new-tab-in-WTDocument-Page/m-p/851658#M69953
17. Windchill: Ely_64 needed Help on deprecated Windchill APIavillanueva delivered an Accepted Solution. Thank you @HelesicPetr for participating!
https://community.ptc.com/t5/Windchill/Help-on-deprecated-Windchill-API/m-p/851664#M69954
18. Mathcad: PavanShetty_077 needed help Extracting Data from 2 variables and terryhendicott provided the Accepted Solution!  Thank you, @JKT for also participating in the conversation!
https://community.ptc.com/t5/Mathcad/Extracting-Data-from-2-variables/m-p/852381#M204890
19. Mathcad: xyz123 experienced Convergence problems with functions and sampled signals and ttokoro helped with an Accepted Solution. Thank you @Werner_E for participating as well!
https://community.ptc.com/t5/Mathcad/Convergence-problems-with-functions-and-sampled-signals/m-p/852158#M204871
20. Arbortext: "can someone explain me about ttrevclear how to let it work?" was eyeung's question, which received an Accepted Solution from ChrisWestern. Thank you!
https://community.ptc.com/t5/Arbortext/can-someone-explain-me-about-ttrevclear-how-to-let-it-work/m-p/848669#M32780
Andra
0 REPLIES 0
