I had an issue where the .idx file had been deleted and I could not save anything without crashing.
Several months later the .idx file was there, but possibly corrupted. After crashing, things worked again when a old one was reinstalled.
Same thing happened yesterday.
In this thread:
Re: Getting booted out of WF5/Creo
Martin Hanak talks of recreating the .idx file:
But when I try this, it crashes again. I thought maybe if I made a "new" one, things would be better.
Any thoughts?
(I did save a back up before trying this so at least I am not dead in the water.
did you test Update Index command with different family table model in different directory ? This test should tell you if the problem is related to specific model -OR- if it is general. If the problem is related to specific model, then you can ask PTC Support to repair it (this is my guess).
MH
MH
We have switched to Creo 4.0 and that now works. I did not find an answer for WF5.0 though.
