Community,
I went from Creo 6000 to Creo 6040, and I cannot find the ifx fastener data, as shown highlighted below. I have never encountered this before, even with the Lite version. Is there a way to fix this? Thanks in advance.
In your picture you point to the AFX directory, not to the IFX directory?
Oli
Hi ThoRig,
please refer to this post: https://community.ptc.com/t5/Assembly-Design/Can-t-Use-ANSI-Fasteners/m-p/666210#M20609
This will show the solution for your problem.
Oli
Thanks for responding. I have that in my config file, and it still does not work.
Oli
Good point. I missed that. I will take another look at it.
That was the problem. Thanks.
