We are aware of an issue causing intermittent login problems for some users following a recent update. Learn More
I am using Creo Parametric Release 4.0 and DatecodeM150
We currently face a challenge in opening “.lay files”.
Is that part missing in “PROE_DesignEssG”
"this funcion requieres one of the following:NOTEBOOK
Take a look:
需要 高级模块
need Advanced Assembly Extension
I understand but it looks like Notebook is missing in Creo Essentials.
In Creo Advanced the module Notebook is available but can’t find any article where it is stated that Notebook is NOT available in Creo Essentials.
Creo Essentials only open and Limited modify
can not create
you can see PPT OF Creo Packaging and Solution Capabilities
YOU CAN BUY Creo Advanced OR Creo Essentials + AAX
Unfortunately Creo Essentials does even not open.
Are you able to share the PPT?
