This functionality requires one of: NOTEBOOK
I am using Creo Parametric Release 3.0 and DatecodeM190
while opening .lay file getting below error,
Here are the errors that I faced
Hello @Mahadev
Good news. This means you have NOTEBOOK as part of your floating modules or extensions.
Maybe, all what you need in the ongoing session is to proceed as follows (of floating module):
  • >File >Options >Licenses >Refresh License List
    • If you see NOTEBOOK, check it. After that, you should be able to open the .lay file
    • If you don't see it (or if you see it, but would like to acquire it automatically upon next startup), proceed as follows:
      1. Launch <Creo Parametric Load Point>\Parametric\bin\reconfigure.exe
      2. Choose Next twice, and in Applications to Customize of Creo Parametric 3.0 Installation Assistant, access Customize Applications
      3. Access Command Configuration and Press Edit
      4. Check probable presence of NOTEBOOK probably in Floating Options section (on the left table)
      5. Select it and push it to the right Table (labelled Selected Licenses)
      6. Press Ok, and then Install
Serge
KenFarley
Not really any mystery here. You're trying to open a .lay file, which is a notebook layout file. You don't have a license for the notebook module, so you can't open it. Hopefully your company has licenses available for that module and you just didn't pull one when you started your Creo session.
Mahadev1-VisitorAuthor
Hi KenFarley,
I am new to this area, I don't know how to check notebook license is there or not.
Could you help on this, it would be more appreciate.
Hello @KenFarley
As @Mahadev said, you need NOTEBOOK License to open *.lay files in Creo Parametric. We document this in article 121454.
In order to check which are the modules you have currently access to, Select >File >Help >System Information, and browse down to "Configured Option Modules" section. In the machine where you're facing this, I expect therefore that NOTEBOOK entry is probably not listed.
Serge
