The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hello! Currently, I'm playing around with the Thingworx REST API.
I am trying to connect a ThingShape's visibility to an organizational unit. The highest Unit is "TopOrg" and the one directly below is "Administrator". Below that is "Worker", so TopOrg > Administrator > Worker.
According to documentation I need a "principal" and "principalType"
I've left my principalType to be "OrganizationalUnit", but I can't seem to get a correct "principal". I've tried "Administrator", "TopOrg:Administrator" and "TopOrg/Administrator". In either form, I get an error similar to this.
Unable to Invoke Service AddVisibilityPermission on AdminShape : Invalid Entity Reference: OrganizationalUnit/TopOrg/Administrator
How are principals properly formated?
PrincipalType is Organization
Principlal is "TopOrg" in your case
PrincipalType is OrganizationUnit
Principlal is "Administrator" in your case
Principlal is "Worker" in your case
you have to set separately for each org / orgUnit.
