Hi everyone,
I am beginner with Thingworx.
I have installed Thingworx 8.5 Postgres in my virtual machine based on Azure.
I was able to finishe installation succesfully.
My question is:
How do I access the Thingworx home page? I know that I need to use the addres bellow:
http://<servername>:<port>/Thingworx
Where, my <servername> is my DNS from Azure machine. Image bellow:
And my <port> is 8080
So, I tried to use:
http://xxxxxx.eastus.cloudapp.azure.com:8080/Thingworx
But it did not work..
May someone help me with this?
Leonardo
Since you are able to access ThingWorx from localhost there is no issue with your tomcat or ThingWorx. You may have to open port 8080 in the Firewall settings of your VM.
Do you see tomcat home page if you navigate to http://xxxxxx.eastus.cloudapp.azure.com:8080?
If not, go through the tomcat logs for any error. If yes, then go through the ThingWorx logs which would be in ThingworxStorage\logs folder, especially ApplicationLog. If you are having difficult interpreting them, post the error messages here and we could help.
Hi @rjanardan
I can not see tomcat home when I navigate to Thingworx.
What is the correct log that I need verify?
Another information:
I am able to navigate to Thingworx in my virtual machina (AZURE). Image bellow:
