Combo box Input into an SQL Service
Hey all,
A disclaimer: I'm new to Thingworx and have only been doing this for about 3 months.
My problem: I'm trying to take the output of a multi-select combo box and map it into an insert with a javascript/SQL service.
Let me describe what I'm trying to do: I have a combo box that will allow users to select up to six values. I then bind this to an infotable attached to a javascript service as an input parameter. I have each field declared in a datashape that defines the infotable. My javascript then concatenates the values together separated by a '/'. So my output is value1/value2/value3, etc as a text string. I'm trying to combine the 6 selections into a one row insert. The javascript then calls the SQL insert. Both services work fine when I test in the Thing stand alone. The multiple select in the combo box works fine as I can display the selections in a grid. The rub is that I don't know how to get the output from the combo box selected rows into the fields defined in the datashape/infotable. Is there an easier/better solution besides utilizing 6 different drop down widgets to get this to work correctly?
