How to center align Grid header and value using Style Theme
SOLVED
Highlighted
Pearl
Hello all,
How to center align Grid Header and Value using style theme
/VR
1 ACCEPTED SOLUTION
Highlighted
Re: How to center align Grid header and value using Style Theme
Hi @Velkumar.
Several changes were made affecting widgets in ThingWorx 8.5.1.  It is recommended that you upgrade (the latest release is now 8.5.4).
If you still have issues after upgrading, you may need to look at using CSS to address your issue.
--Sharon
8 REPLIES 8
Highlighted
Hi @einsfeldleo ,
Thanks for your response.
I tried it gridadvanced widget, it doesn't work.
/VR
Highlighted
Hi @Velkumar.
From our testing, we're not seeing an issue.  If you select the grid, in the upper-left corner is a drop-down.  From there you should select Configure Grid Columns.  You then have the ability to align the header or the data.
Please let us know if you're still having issues.
--Sharon
Highlighted
Hi @slangley
Thanks for your response. I have mapped configuration dynamically, so I'm not able to find 'ConfigureGridColumns ' in widget.
In configuration, I have mentioned 'textAlignment' as center
Still header and text are not aligned
/VR
Tags (1)
Highlighted
Hi @Velkumar.
Which version of ThingWorx are you running?
--Sharon
Highlighted
Thingworx 8.5.0
Tags (1)
Highlighted
Hi @Velkumar.
--Sharon
Highlighted
Hi @Velkumar.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
