The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hi @Velkumar
May be that topic help you:
https://community.ptc.com/t5/ThingWorx-Developers/Alignmente-Value-Display-Twx-8-5-1/td-p/644061
Regards
Leonardo
Hi @Velkumar.
From our testing, we're not seeing an issue. If you select the grid, in the upper-left corner is a drop-down. From there you should select Configure Grid Columns. You then have the ability to align the header or the data.
Please let us know if you're still having issues.
--Sharon
Hi @slangley
Thanks for your response. I have mapped configuration dynamically, so I'm not able to find 'ConfigureGridColumns ' in widget.
In configuration, I have mentioned 'textAlignment' as center
Still header and text are not aligned
/VR
Thingworx 8.5.0
Hi @Velkumar.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
--Sharon
