I'm just getting started with my fundamentals ThingWorx class for architects. PTC academy provides a .xml file ("FundamentalsGlobalEntities.xml") which contains the supporting entities i will use to build an IoT application. It wants me to import the .xml file.
In the attached screenshot you will be able to see the message I receive after hitting the import button.
Does anybody know whats the problem and how to solve it?
Thank you so much for you help
Kind regards
Philipp
Hey,
i solved the problem. Our Admin didn't give me the rights to do anything but read....
Thank you for your help!
Can you tell me how to find the application logs error? What is platform-setting.json? Sorry for asking stupid questions but I'm completely new to PTC ThingWorx
The only thing I found is "LOGS" in the monitoring section, but it seems to be empty or at least it doesn't open.
Hi @PD_9717258 , You can search for log on the thingworx installation folder under <ThingworxStorage>/logs.
Regards
Ankur
Hey,
Hi @PD_9717258.
Since you found the solution, please mark your last response as the Accepted Solution for the benefit of others with the same issue.
--Sharon
