Import of xml file (entities FundamentalsGlobalEntities.xml) failed
PD_9717258
I'm just getting started with my fundamentals ThingWorx class for architects. PTC academy provides a .xml file ("FundamentalsGlobalEntities.xml") which contains  the supporting entities i will use to build an IoT application. It wants me to import the .xml file.
In the attached screenshot you will be able to see the message I receive after hitting the import button.
Does anybody know whats the problem and how to solve it?
Thank you so much for you help
Kind regards
Philipp
PD_9717258
(To:anarwal)
Hey,
i solved the problem. Our Admin didn't give me the rights to do anything but read....
Thank you for your help!
anarwal
(To:PD_9717258)
Spoiler
Hi @PD_9717258 , Could you share the application logs error. You also can check platform-setting.json if import are allowed.
Ankur
PD_9717258
(To:anarwal)
Can you tell me how to find the application logs error? What is platform-setting.json? Sorry for asking stupid questions but I'm completely new to PTC ThingWorx
The only thing I found is "LOGS" in the monitoring section, but it seems to be empty or at least it doesn't open.
anarwal
(To:PD_9717258)
Hi @PD_9717258 , You can search for log on the thingworx installation folder under  <ThingworxStorage>/logs.
Ankur
PD_9717258
(To:anarwal)
Hey,
slangley
(To:PD_9717258)
Hi @PD_9717258.
Since you found the solution, please mark your last response as the Accepted Solution for the benefit of others with the same issue.
--Sharon
