Libraries Google Maps
AC_9552412
11-Garnet
Hi, I want to use the geometry and drawing libraries from google maps, I have updated the metadata.xml file adding libraries=geometry,drawing, but I don't get the corresponding options in the map widget, is it necessary to make more changes in the code for it to work properly?
PEHOWE
(To:AC_9552412)
@AC_9552412 ,
From the screen capture you added code to "googlemap.ide.js".
There should also be code added to "googlemap.runtime.js" which makes the approate updates.
The updates include adding the option "drawingControl: true," to options when the item is checked.
You also added the drawing library:
googleMapsConnectionString = _invoker.result.rows[0].GetGoogleMapsConnectionString + "&libraries=drawing";
When defining an instance of the Google Map you need to create an instance of the map object. This looks like
 = new google.maps.Map(document.getElementById("map"),
from the Google Maps Documentation. When reviewing the "googlemap.runtime.js" we find:
thisWidget.map = new google.maps.Map(document.getElementById(thisWidget.jqElementId), options);
This creates a Google Map object. From the google documents you need to load the drawing manager. You need to add code which looks like:
thisWidget.drawingManager = new google.maps.drawing.DrawingManager({
    drawingMode: google.maps.drawing.OverlayType.MARKER,
    drawingControlOptions: {
    position: google.maps.ControlPosition.TOP_CENTER,
	drawingModes: [
	google.maps.drawing.OverlayType.CIRCLE,
	google.maps.drawing.OverlayType.POLYGON,
	google.maps.drawing.OverlayType.POLYLINE,
	google.maps.drawing.OverlayType.RECTANGLE,
    markerOptions: {
       icon:					"https://developers.google.com/maps/documentation/javascript/examples/full/images/beachflag.png",
    circleOptions: {
	fillColor: "#ffff00",
	fillOpacity: 1,
	strokeWeight: 5,
	clickable: false,
	editable: true,
	zIndex: 1,
thisWidget.drawingManager.setMap(thisWidget.map);
The above is based on the Google Maps https://developers.google.com/maps/documentation/javascript/examples/drawing-tools
Let me know if you have any questions.
Peter
8 REPLIES 8
PEHOWE
(To:AC_9552412)
@AC_9552412 , I have done one simple modification to the Google Map Widget, I added "NiteMode" to the available map skins. There is more to modify then adding a line to the metadata.xml file.
If you can explain what you options expect to see in the Widget,
I may be able to point you in the proper direction.
If you are expecting to see a new control or option you would need to update googlemap.ide.js or googlelocation.ide.js. There would also be a matching update to the googlemap.runtime.js or googlelocation.runtime.js to make the UI change functional.
Hope That helps
Peter
hi @PEHOWE ,
I want to show all drawing options
PEHOWE
(To:AC_9552412)
@AC_9552412 ,
Can you provide an example of a field which is not available.
If you look at the current Google Map Widget
The infotable allow shapes and route data to be displayed.
PEHOWE
(To:PEHOWE)
@AC_9552412
Is this the tool bar you are trying to add?
Can you share how you changed the configuration to add the libraries?
That is the bar I want to add
Hi @PEHOWE,
All the options you see in your image are displayed but this option should be displayed, which is the one I'm missing.
PEHOWE
(To:AC_9552412)
@AC_9552412 ,
	drawingModes: [
    markerOptions: {
    circleOptions: {
	fillOpacity: 1,
	strokeWeight: 5,
	clickable: false,
	editable: true,
	zIndex: 1,
Peter
slangley
(To:AC_9552412)
Hi @AC_9552412
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
