Hello folks,
I followed the steps from the Create Your Application UI tutorial (starting at minute 29:09 2min,left- https://youtu.be/BOuJMFDwcHg?t=1749) and I have a problem with the Data Property 'Automatically update values when able'. The values do not change automatically, only by using the 'reaload'-button.
Version: ThingWorx 9.2.1-b112
Also, new ApplicationKeys are generated all the time..
Best regards
For whatever reason it looks like it is having trouble maintaining the 'session' that forms the pipeline to push value updates.
As far as why that might be happening, I am not sure, you may need to get help from ThingWorx Tech Support
Hi @M4RC.
If you feel the previous response was helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
