Mashup Automatically update values when able not working
M4RC
9-Granite
Hello folks,
I followed the steps from the Create Your Application UI tutorial (starting at minute 29:09 2min,left-  https://youtu.be/BOuJMFDwcHg?t=1749) and I have a problem with the Data Property 'Automatically update values when able'. The values do not change automatically, only by using the 'reaload'-button.
Version: ThingWorx 9.2.1-b112
Also, new ApplicationKeys are generated all the time..
Best regards
This project will introduce the ThingWorx Mashup Builder through the use of an instructional video.Following the steps in this video-guide, you will learn ho...
PaiChung
(To:M4RC)
For whatever reason it looks like it is having trouble maintaining the 'session' that forms the pipeline to push value updates.
As far as why that might be happening, I am not sure, you may need to get help from ThingWorx Tech Support
PaiChung
(To:M4RC)
slangley
23-Emerald I
(To:M4RC)
Hi @M4RC.
If you feel the previous response was helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
