We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Dear all,
this Topic is already well know here, but I haven't found a solution, so I'll post the problem here:
I want to install TW 8.1.3 (on a Microsoft 2012R2 OS), installed PostgreSQL 9.4.17 and Tomcat 8.5.29. When deploying the thingworx.war, Tomcat crashes and doens't start anymore.
From the log files I could't extract:
2018-03-16 17:53:23.764+0100 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Failed to load FlxCore library. Ensure it's in PATH (Windows) or LD_LIBRARY_PATH(other platforms) or set with the VM arg, -Djava.library.path. Error message : com.flexnet.licensing.DllEntryPoint.entry([B)I
Regarding another post mentioning the -Djava.library.path - mine is set to:
-Djava.library.path=D:\Apache Software Foundation\Tomcat 8.5\webapps\Thingworx\WEB-INF\extensions
From the Tomcat logs I found the following:
6-Mar-2018 17:53:14.670 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath
The system environment variable is pointing at the following: D:\Postgres9.4.17\bin
Similar issues are mentioned here:
https://community.ptc.com/t5/ThingWorx-Developers/Thwx-7-4-Failed-to-load-FlxCore-library/m-p/520920
https://community.ptc.com/t5/ThingWorx-Developers/Failed-to-load-FlxCore-Library/m-p/515114
Can anybody support?
I see you're on a newer version of Tomcat. Will you double check that the extra parameters you added, including -Djava.library.path, are in the "Java Options" box, and not the "Java 9 Options"? When I move my parameters to the Java 9 Options box, I am able to reproduce the same errors as you.
Also, make sure your ThingworxPlatform folder is on your D:\, as that's where you have Tomcat installed.
Tony
Thank you for you support, the problem got solved during my absence. The issue was a wrong Java Version (32bit).
Benedikt
Hi @beisler,
For the benefit of the rest of our Community, can you please indicate your response as the Accepted Solution?
Thanks!
Leigh
My colleague uninstalled everything and installed TWX again. As I said, the problem was 32bit Java application (64bit needed).
Benedikt
