Aug 22, 2017 12:24 AM UTC
Trouble starting ThingWorx after fresh installation
I've seen other threads on this and have tried the solutions without any luck. I am getting a 404 error message.
Could I please get on a WebEx with someone to help me through it?
Thanks!
20-Turquoise
Aug 22, 2017 12:45 PM UTC
Could you please attach your application log and catalina.out logs (found in ThingworxStorage/logs and tomcat-installation-folder/logs)?
Hitting a 404 means the application cannot be found, so something definitely went wrong during the install.
mlundblad1-VisitorAuthor
Aug 22, 2017 5:33 PM UTC
The requested logs are attached.
Morgan
20-Turquoise
Aug 22, 2017 5:36 PM UTC
ocalhost-startStop-2] Failed to load FlxCore library. Ensure it's in PATH (Windows) or LD_LIBRARY_PATH(other platforms) or set with the VM arg, -Djava.library.path. Error message : com.flexnet.licensing.DllEntryPoint.entry([B)I
Points to the license issue. Please ensure the license.bin is in the ThingworxPlatform folder (created in the root of the same partition where tomcat is installed - otherwise specified in the  THINGWORX_PLATFORM_SETTINGS environment variable per the isntallation guide.
You may refer to this post about the setup 7.4 Thingworx does not launch due to license error in Windows
Aug 25, 2017 10:46 AM UTC
Try to put C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEB-INF\extensions in System Variable called Path, cause I saw that you have it only in user variables.  It helped in my case.
Dec 29, 2017 12:32 PM UTC
HI did you solve the issue?? i am facing same problem
Dec 29, 2017 2:08 PM UTC
There are some good Foundation Server installation troubleshooting tips here.
