I used to have more than 30 guides in my thingworx profile under the part "Your guides".
I just have 3 left which are the more recent.
Is there a reasons why all my guides just reset ?
ps : I don't know if this is the right place to ask this question. If it is not, i will move the topic.
Thanks for bringing this to our attention. You should be able to see your past projects now. Apologies for the issue.
Hi, Clement.
Could you send me a screenshot of the 'your guides' list you're referring to? That's not a part of the board's functionality we use regularly so I'd like to look further into this.
Thank you,
-- Craig A.
Here is my capture. I used to have 30 guides. I only have 4 now. It isn't a really important for me but i wanted to warn about this bug.
The guides are here. Are you just informing about how some guides in which you were enrolled in, have disappeared from under Your Guides section?
Yes because I don't thinks it is an intentional feature.
Hi @Clement_D.
Please provide the url so we can validate we're referring to the same thing. I can then follow up with the team that supports that site for more information.
Regards.
--Sharon
No problem.
Thank you, I have recover my progression :)
I wanted to say that the guides and the interface with the progression are very nice.
