I am pulling external data into Vuforia Studio from Thingworx. However I want to filter the data being displayed. I attached a photo below of my infotable and my question is: Is it possible to only display data where "shelf_number" is equal to [x] within Vuforia?
Thank you!
Hi @morganweiss33 ,
the answer is yes, it is possible.
2 options:
1.) option 1. )my favorite - if you anyways use a service from Thingworx you can define a second service where you call the first service/ or direct value query (e.g. QueryNumberProperty ) and filter it with query where you pass your filter parameters. As example you can check the following topic ( it is more complex example as your case):
External Data - Date&Time format
Problem with Time Series Chart
you can call you service later with some code like this below
$scope.app.runMyTWXService = function() {
var TWXmodelID = 'PlatformSubsystem';
var serviceName = 'GetAllStateDefinitions';
var parameters = {'propertyName': 'Temp', 'maxItems': 10};
//twx.app.fn.triggerDataService(TWXmodelID, serviceName, parameters);
//return twx.app.fn.triggerDataService(TWXmodelID, serviceName, '{}');
return $scope.app.mdl[TWXmodelID].svc[serviceName].data;
var values= $scope.app.runMyTWXService();
console.log("value in $scope.app.getListStates()");
console.warn(values)//print the values in the console STRG-Shift-I
2.) You can call the data and filter it in the javaScript loop / not so sufficient but for a simple case as in your example it could work fine:
//function which calls QueryNumberPropertyHistory
//with parameters
var TWXmodelID = 'TES_stream';
var serviceName = 'QueryNumberPropertyHistory';
var parameters = {'propertyName': 'angle', 'maxItems': 30};
// myTest is called by UI button for testing see picture
$scope.myTest=function(){
$timeout(function()
{console.log('retData')
var retData=$scope.app.mdl['TES_stream'].svc['QueryNumberPropertyHistory'].data
$scope.RESULT={}
$scope.myFilter_min=50
//any value to demonstrate a filter function here value should be > as min value
var count=0;
retData.forEach(function(value){
console.log("value["+ (count++) +"]="+JSON.stringify(value))
if(value['value'] > $scope.myFilter_min) $scope.RESULT=value;
//the first value which exceed the min filter
}) },600)
$timeout(()=>{console.warn("$scope.RESULT="+JSON.stringify($scope.RESULT))},2000)
Then we can check e.g. the resutl in console:
For such static tables you can also pass the data as parameter in external data and set the configuration to call it on statup - in this case you can call the service result directly :
Hi @morganweiss33 ,
You can bind the infotable result to 2D Data Grid widget in Vuforia Studio. The widget allows you to select which column to display.
Please refer the guide for more information.
Thank you. I was able to do that, my question is: Is there a way to filter what is shown based on a property. One of my values is "shelf_number" so I only want to display values on my data grid where "shelf_number === [x]".
Hi @morganweiss33 ,
2 options:
//with parameters
$timeout(function()
$scope.RESULT={}
var count=0;
}) },600)
