Hey,
What I am reporting used to work and within the space of roughly 1-3 weeks it no longer works.
I ran though the Fundamentals of AR Development course in PTC University and managed to complete the IoT Robot Arm Repair Project. The Project worked nicely where it was pulling IoT data from the RoboArm1 Thing on the ThingWorx Platform. For some reason now, the 3D gauge never updates with new values... Even though the service configuration is correct, see below
Any help please? Did the Vuforia Studio update affect this?
Hello Ryan,
Maybe the best is to schedule a WebEx session.
I will contact you directly by email.
Best regards,
Samuel
Hello Ryan Anderson,
In Vuforia Studio, in Preview when reproducing the issue, what is the output in Chrome, in Developper Tools, in Console tab ?
Best regards,
Samuel
Hey Samuel,
Here is the output:
BR
Ryan
Hello Ryan,
I suppose that the data is not updated to the javascript exception thrown.
The solution is to solve it.
I have some questions :
Thanks you in advance for your feedback.
Best regards,
Samuel
Hey Samuel,
Yes I do, I followed the "Fundamentals of AR Development with Vuforia Studio" Course on PTC University and followed exactly as presented (as mentioned it previously worked until I tested once again today).
See elbowGauges function below:
...And see that I call elbowGauges in a Model Item Click Event:
BR
Ryan
Hello Ryan,
Please send me the Project, it will be easier to have a deeper look.
Thanks you.
Best regards,
Samuel
Hey Samuel,
I've attached the project in question.
TIA
Ryan
Hello Ryan,
When disabling Auto-Refresh ..etc.. linked to Properties of ThingWorx, I can execute this Javascript code without any problem.
Best regards,
Samuel
Hey Samuel,
I assume I still have access to the Things, Properties and Service. I am still able to login to my ThingWorx Composer instance @ https://twx.studio-trial.vuforia.io/Thingworx/Composer/
I also tried disabling Auto-Refresh on my properties and services and that did not work for me unfortunately.
I'm not sure if this is the logging you are after...
Hey there,
Any Updates?
Hello Ryan,
We have reviewed this issue in an internal PTC meeting between Technical Support engineers.
To be honest, we think that's the issue can have 3 possible root causes :
The steps to investigate issue 2 are :
To investigate issue 3 :
Best regards,
Samuel
Hey Samuel,
Here are my answers below in red:
Any other ideas? 😞
Hello Ryan,
Please send me in aprivate message this user and password. I would check if I am able to reproduce the issue locally here at PTC with in a more close environnent like you.
If I am able to reproduce the problem, it will help to find the root cause and the solution.
Best regards,
Samuel
Hey Sam,
I think I will need a little help with this. I'm not sure I can do any admin-tasks on this PTC Cloud-hosted ThingWorx solution.
Please PM me if required, else reply here.
TIA 🙂
Hello Ryan,
Best regards,
Samuel
Done, and appreciated.
