Good Morning,
I have offline downloaded AR experience created using Vuforia Studio in Hololens 2 Vuforia View app.
Whenever I click on a button to set the sequence in Hololens 2 the system sometimes work & sometimes it goes blank.
Can I get any help on this.
Best Regards,
Aditya Gupta
Hello @Aditya1702 ,
if the issue still occur, we need to clarify it further. what means goes blank - is that crash of the view app? Or is that an issue of the model - so not properly is displayed /e.g. some shader setting etc. . For example the shader setting on HL are different for View GLSL and HLSL for HoloLens and they are not working on the different modes. So could you reproduce the issue in preview or only in view
another point is the question: what do the button to set the sequence /figure? Is that with binding on widget or did you call some javascript code? When you call javascript to set the sequence possibly is that some kind of javascript synchronous problem. Possibly some code is not synchronized - because the js code is always working asynchronously
