The message you are trying to access is permanently deleted.
3440
Views
| I love learning which is probably why I teach classes. I first learned
the basics of sheet metal as ...
3440
Views
11189
Views
| Happy New Year, PTC Community! After my guest talk Class A Creo
Surfacing on 11/21, the PTC Communit...
11189
Views
I am using Creo Parametric 11.0.6.0. In AutoCAD, there is a feature
called compare with which we cou...
23
Views
by
ErikClacey
1 Reply
166
Views
| In the piping line stock there first tab, one can specify bend radius
and bend angle with multiple v...
1 Reply
166
Views
68
Views
| Creo 8, ModelCheck, Windchill 12; (soon Creo 12, Windchill 13) 1.
3D-models have layers with status ...
68
Views
by
Matthijs1
23
Views
| Hello everyone, I'm building some mapkeys to create some basic
functionality that PTC forgot to add ...
23
Views
by
PU_14258916
1 Reply
48
Views
| I am using Creo Parametric Release 4.0 and DatecodeF000I need to store a
background image used in a ...
1 Reply
48
Views
by
CM_10790883
537
Views
| I am using Creo Parametric 10.0.4.0 and performing a Model Check on a
part and I am looking at the w...
537
Views
160
Views
| We are actively moving to SharePoint data storage. Can assembly be
organized with Parts in multiple ...
160
Views
by
Mat
206
Views
| Hi there, I have a frustrating problem with Model Check. We use screws
in our assemblies. Those scre...
206
Views
by
N-Pyn
1386
Views
| Hi everyone, Almost every design and manufacturing company uses some
parts that are created by cutti...
1386
Views
by
JL_10988197
1 Reply
36
Views
| I am using Creo Parametric Release 4.0 and DatecodeM100 遇到严重错误。回溯已写入
Here are the errors that I face...
1 Reply
36
Views
by
Yogesh.T
103
Views
| I In .drawing the way to bring an image is clean and nice resolution.
WHY in .format, it has differe...
103
Views
by
DS_10589664
507
Views
| Hi,I am working on a large assembly file which contains a sub assembly
that is modelled with flexibl...
507
Views
by
Airfix
326
Views
| I'm very new at compound surfaces. I'm using Creo 9 and I'm trying to
create a surface from a sequen...
326
Views
by
PC_14365112
147
Views
| Hello, I have partial 3D scan (.stl) of impeller that needs to be
converted to CAD model. I cut the ...
147
Views
by
Huug@Kuhn
635
Views
| I have a hard time substituting some components in an assembly with a
simplified representation usin...
635
Views
87
Views
| How to protrude image 1 text vertically as in image 2 drawing?
87
Views
by
khimani_mohiki
1940
Views
| So this is slightly linked to Windchill, we got our Extended Position
Assemblies working by changing...
1940
Views
by
Srinivasan_Iyer
337
Views
| We are using Creo Parametric 10.9 How do industries tackle the issue of
Identical parts with the dif...
337
Views
7956
Views
| Hi all, I have a curve driven pattern that is propagating in the wrong
direction. I rerouted my sket...
7956
Views
3127
Views
| I'm looking for an option to reset component display style. One of our
users set the component displ...
3127
Views
by
YHAdesign
195
Views
| Hi everyone, I am a user of CREO Parametric 12.4.0.0 Academic Edition. I
created a quite complex mul...
195
Views
by
TO_14078118
164
Views
| Hi, working in creo 11 relative newbie here, im making a n64 controller
for a uni project and cant t...
164
Views
by
SJ_10265581
1 Reply
64
Views
| I am creating hole table from points and customized the table according
to requirements i,e added so...
1 Reply
64
Views
181
Views
| Hello, I have an imported part and i would like to create a sketch which
would be the projection of ...
181
Views
by
JD_10990819
1 Reply
81
Views
| I am using Creo Parametric Release 10.0 and Datecode10.0.9.0 Bonjour,
nous rencontrons un problème a...
1 Reply
81
Views
by
Patriot_1776
6521
Views
| Creo 8: I tried this earlier, in an admittedly more tricky version, that
didn't work. P!$$ed me off,...
6521
Views
by
DH_14427784
241
Views
| Hi Community, 🙂I am new in this forum. I have medium experience in Creo
Parametric (version 8 ) and...
241
Views
by
LH_10601291
1 Reply
72
Views
| Hi everyone, I have created a part with two bodies and assigned a
material to each of them. Now I wa...
1 Reply
72
Views
by
edssysad
51
Views
| I am using Creo Parametric Release 5.0 and Datecode5.0.0.0 we are facing
issue for Creo This fatal e...
51
Views
by
SD_14219997
807
Views
| I am using creo parametric 10.0.2.0 I have a schedule in my drawing that
is using a 2-D repeat regio...
807
Views
| User | Count |
| 6 | |
| 4 | |
| 4 | |
| 2 | |
| 2 |
| Subject | Author |
