7-Bedrock
December 23, 2025
Overlay of drawings for checking
  • December 23, 2025
  • 2 replies
  • 158 views
I am using Creo Parametric 11.0.6.0. In AutoCAD, there is a feature called compare with which we could compare the drawings and find out the changes that are made. Sample_Overlay.png
In the above image, the holes are changed from Dia 10 to Dia 8. On using the compare tool, the affected regions highlighted with cloud like marking.
Is there an equivalent feature in Creo that does the same function as above?
tbraxton
Drawing overlay. Check out this video from @DaveMartin .
https://www.youtube.com/watch?v=HPDmLWk11qs&t=1s
One can do the comparison at the Model Level too.
Check out Tools --> Compare Part
At the Drawing level:
