Installation fail
PB_9720152
Installation fail
Good day!
After running the installation file (pim_installmgr_mathcad) and after the execution is over - nothing happens and nothing is installed.
Tried all compatibility settings and I still can't install the program.
15 REPLIES 15
What version of Mathcad Prime and Windows OS are you using?
PB_9720152
(To:VladimirN)
Windows 11 Pro N, Version 21H2
Mathcad Express - actually don`t know what version, downloaded from the Mathcad Student Downloads
@PB_9720152,
Could you try downloading Mathcad Express from this link? - https://www.mathcad.com/en/try-and-buy/mathcad-express-free-download. See if it helps.
PB_9720152
(To:rghadge)
thanks for trying, but it didn't help ;(
PB_9720152
(To:VladimirN)
after I run the installation file - nothing happens
Same things Happen with me.
What is the size of the installer you got?
LucMeekes
(To:PB_9720152)
Did you follow the installation rules as set out here:
https://community.ptc.com/t5/Mathcad-Installation/Step-by-Step-Installation-Procedure-for-Mathcad-Prime-8-0/td-p/789358
Especially:
"execute/run pim_installmgr_mathcad.exe,  run as an Administrator."
PB_9720152
(To:LucMeekes)
after this step - nothing happens and nothing is installed, the window closes and that`s all.
LucMeekes
(To:PB_9720152)
And you DID run pim_installmgr_mathcad.exe as an administrator...?
PB_9720152
(To:LucMeekes)
yes
PB_9720152
(To:LucMeekes)
I have seen these articles, tried to reinstall what is specified and it didn't help...
But thanks!
LucMeekes
(To:PB_9720152)
I propose you start a support case. https://www.ptc.com/en/support/
