What version of Mathcad Prime and Windows OS are you using?
Windows 11 Pro N, Version 21H2
Mathcad Express - actually don`t know what version, downloaded from the Mathcad Student Downloads
Could you try downloading Mathcad Express from this link? - https://www.mathcad.com/en/try-and-buy/mathcad-express-free-download. See if it helps.
thanks for trying, but it didn't help ;(
after I run the installation file - nothing happens
Same things Happen with me.
What is the size of the installer you got?
Did you follow the installation rules as set out here:
Especially:
"execute/run pim_installmgr_mathcad.exe, run as an Administrator."
after this step - nothing happens and nothing is installed, the window closes and that`s all.
And you DID run pim_installmgr_mathcad.exe as an administrator...?
yes
Apparently, Prime installation will not run on some machines, see here:
and here
I have seen these articles, tried to reinstall what is specified and it didn't help...
But thanks!
I propose you start a support case. https://www.ptc.com/en/support/
